I want a fully off-grid system with Victron—who can help me?
Now that I have a digital meter, I would like to install batteries.
I am not allowed to change anything in my existing configuration, otherwise I will lose my certificates (Belgium). So, instead of sending the electricity converted by my panels to the grid, I first need to make sure my batteries are charged, and only send it to the grid once they are full. I need to have the option of going completely off-grid.
My panels provide a peak output of 8,500 watts in total. My current situation:
2 SMA (Sunny Mini Central SMC 4600A) inverters that feed the electricity into the grid on a single phase over two phases; I must not alter these.
What do I want?
I want to send the electricity generated by my panels / SMA units to my batteries first, and only send it to the grid once they are charged. The batteries must be able to supply three-phase power.
I want to work with
Victron MultiPlus-II 48V 6.5kVA 100A (3 units), because I also have a heat pump, but I would like to supply the rest of my house with electricity as long as there is enough charge in my batteries.
I have already done my research, and this is what I will need from Victron:
Victron Energy Cerbo GX MK2 ControllerVictron
Energy Lynx DC Distributor (M10) (2 units)
Victron Energy VM-3P75CT Energy Meter
Victron MultiPlus II 48V - 6K5VA - 100A (3 units)
Which battery? I would like to go for 25 kWh.
And I will also order the necessary cables and fuses.
The only thing I am missing is a wiring diagram showing me how to install everything.
Could anyone help me further?
Many thanks in advance.
The best advice is to contact your local official Victron dealer for system design.
What you have in mind is perfectly feasible; I would use the system as a standard ESS. Going fully off-grid won’t work with “only” 25 kW of batteries.
My system is a three-phase MultiPlus II 5k with 20 kW of Pylontech batteries and 9,600 Wp of solar. My entire house runs on it, and now a heat pump as well. Even with this setup, going off-grid isn’t possible, although we use very little power from the grid between March and November.
A three-phase heat pump? In that case, a 25 kWh battery is rather small. Here I have a single-phase heat pump behind the Victron with 32 kWh of batteries, but even that could have been 45 to 50 kWh… Don’t underestimate the power consumption of the heating element; last winter, I once reached 10 kWh in a single day purely for defrosting.
What is the power rating of your heat pump? The Bosch 5800iaw 7OR-S runs perfectly well here on 20 kW batteries.
About 2200 watt for the compressor at 2 or 3 degrees of frost, I have seen 4300 watts at a defrost. Panasonic monoblock, unit bought in 2019
I’ve read several times that you have the Bosch 5800 heat pump.
Does it start up without any problems on the MultiPlus in off-grid mode?
Yes, it indeed works fine when the power goes out.
What kind of MultiPlus do you have?
Hope the heat pump also runs on a 3000 without the auxiliary heating.
3x multiplus 2 5000
The house is too small for that :wink:
