Hello All.
Quick intro and disclaimer, I work for a power equipment supplier here in New Zealand in our Generator division.
About 3 years ago we brought in some Hybrid Generators from an existing supplier: Trime Group. These all use a lot of victron products, Quattros, Cerbo GX, MPPT Solar etc. Selling products like this into our market has been somewhat of a challenge but they can have upto 80% fuel savings so they are very interesting with tangible benefits. While I have reletively good knowledge of power related stuff in a diesel generator context, the entirety of my victron experience has come from experimenting, troubleshooting and learning on these products so my knowledge is reletively narrow/specific and I dont exactly have a great depth of experience.
On our 15kva 3 Phase Hybrid product, with the following spec:
- Diesel Generator with Yanmar 4TNV88 Engine and Linz PRO18M E/4 Alternator. (400V, 50Hz, 0.8PF)
- 4x MG Lithium LFP 230Ah 25.6V Batteries
- 3x Victron Quattro 48/5000/70-100/100 230V VE.Bus
- Victron Cerbo GX
- GX Touch 50
- GX LTE 4G
- Deep Sea DSE3110
- Small amount of solar (4x Victron 40W-12V Mono) with MPPT 150/35
- We have since added some 12v cooling fans on the end of the inverter panel to manage temperature.
Question time: How can I extract every ounce of power out of this thing?
This is difficult to explain as I am not 100% confident in the correct vernacular but long story short this is set up to obviously provide power from the batteries up to 10kw, which if this condition is reached for longer than 5 seconds, the engine automatically starts and provides additional power of up to 15kW via load sharing in our diesel generator world we would think of this has paralleling I believe (I think victron calls this power assist?)
This is designed with an oversized 42kVA alternator to ensure better quality voltage regulation and thermal headroom, and paired with the yanmar 4tnv88 engine (19.8KWe) technically speaking this should be able to produce the following numbers:
Prime Power 18kW / 22.5kVA / 32.5A
Standby Power 19.8kW / 24.8kVA / 36A
Now I understand that the current method of power delivery is bottlenecked by the inverter hardware. However, even when we reach absolute limit of draw at the moment, it is still able to send about 2.5kW of charging to the battery pack, meaning that it is capable of paralleing somehow… (at least thats the theory in my brain) basically what I want to understand is it possible to extract some more power out via either some form of configuration or settings changes as one of its current applications just keeps tripping it at 15kW and its only a short period of time (5mins, its a coffee machine on a movie set) with its constant load of running some lighting, laptops, fridges etc only really being an average of around 3-5kW. if it could briefly sustain 17-18kW via the engine paralleling that would be incredibly helpful. I am very aware that it would not be wise to expect it to produce this maximum figure for extended periods of time but having that peak ability would be fantastic.
Am I dreaming? You tell me. If this is possible, I would appreciate the help, If it is impossible, I would be interested to learn/explain why it cannot be done. As you can imagine, the manufacturer does not want to help and warranty has long since passed on this particular machine so no worries. The simple option is possibly to just upgrade the inverters I guess but I want to try and achieve something with what I already have. Thanks in advance, hopefully I have provided enough context and infomation.
