How to read and modify parameter "user adjusted consumption forecast"?
hi all,
several limitations of dynamic ESS (DESS) were already mentioned in parallel topics.
when it is about consumption-forecast in relation to charging electric-vehicles it would be good to adjust the the forcecast in node-red directly. By that the DESS-algorithm would be able to consider adequately w/o weird workarounds.
in the extended dashboard of VRM I found via “customized widgets” the parameter “user adjusted consumption forecast (kWh)”:
My hope is, that here the forecast can be modified manually. But I neither get data in the widget, nor i was able to find this parameter in node-red.
Therefore my question to the community: any experience or background-knowledge on that parameter?
I’d be curious about this as well… wondering if it can can be leveraged to improve DESS performance (e.g., DESS not accounting for the power needed for the Victron system itself)
See here:
