How to fake an AC generator for VRM
Hello guys,
I have the following configuration:
ESS with 3x Multiplus 2 3000
3x SmartSolar MPPT 250/100
Fronius 10kw (at AC In)
140kWh battery.
Smartshunt between DC side and complete battery bank.
Everything works so far.
Now I would like to feed in the power from externally on the DC side if necessary.
I took another Smartshunt and connected it to Cerbo via VE Direct.
I configured the Smartshunt as a DC generator.
You can see the DC generator in the overview on the Cerbo.
Unfortunately, this and its statistics are missing from the VRM portal.
It is correct, but later incomprehensible data.
For example, in the VRM portal I see:
AC Loads: 1000 watts
Solar: 0 watts
Battery discharge: 200 watts.
That’s right because the remaining 800 watts come from the DC generator. But I would like to be able to trace later where the electricity came from.
I already understood that it simply doesn’t work with the Smartshunt.
I would ideally like to display the Smartshunt from the DC generator as an AC generator in the VRM portal.
The following values ​​are currently in the VRM dashboard: consumption, solar, battery.
With the AC generator I would also get it as a display. This way I can later look back retroactively on which day/month I used the generator and how much electricity it generated.
Now the big question: how do I indirectly bring the DC feed into the VRM portal as an AC generator?
Thank you
Best regards Alex
Hi Alex,
Interesting route you are following here.
Having the same thoughts charging the batteries directly from a generator.
What DC source did you use?
I am thinking of one or two smartsolar 250’s fed by a short cirquit resistant DC supply of 200-250V.
Another option is to just feed in enough amps at 52-53V to charge the batteries when grid fails without available sun and empty batteries.
Statistics are irrelevant when you want to keep your house cosy and warm during a grid outage.
