Hello everyone,
I want to configure the AC IN current on the MultiPlus II (10kVA) based on the Aux1+ and Aux1-. However, on VRConnect or directly on my Ekrano, I can’t find anything about the auxiliary channel…
My goal is to connect the auxiliary channel to a 3-position switch. If the switch is connected to Aux1 and is closed, I want to set the current limit to 16A. If my switch is in the other position and Aux2 is closed, I want to set the AC IN current limit to 32A.
Thank you, If you can help me ![]()
