Is there any significant changes in SW implementation or default setting according to PV power distribution between battery and EVCS during EV charging? Because it seems that above min. SOC in Auto mode, all PV power is distributed to EV and almost nothing to the battery (= EVCS priority).
most people actually want as little as possible to the battery during car charging - you can also set this value manually via ModbusTCP. At your own risk: It is 5081 ‘Battery powered’. BKPB balance power (Register List V3.2)
Thanks for info @Victroniker ! And register 5082 (BKPB balance SOC max) determines max. SOC battery value for PV power distribution during EV charging and above this value all PV power goes into EV?
