How do I access the relay on a phoenix smart inverter
Hi
I have.a Phoenix smart 24/5000 with cerbo GX
I can access the relays on the GX ( although it’s after wading through a lot of menus on the “ remote “ menu but I can’t work out how to turn on and off the relay on the inverter.
Any advice on how I can turn the inverter relay on and off ( remotely )
Thanks.
What do you understand by remotely?
By Software- or Hardware Solution ?
Hi
By the remote console - so software ?
A software solution is difficult or even impossible because there is no Modbus address for activating the relay.
You can only switch the inverter to On/Off/Eco
That’s interesting. Why do they even have a relay ?
If you have access to the dbus path of that relay and changing the value there the relay turns on and off, then the Modbus address is not a problem.
You can either:
  1. You can manually add / allocate an address for that path on the Modbus config in order to use Modbus.
  2. Create the entry on the Remote Console to control that dbus path.
But both of these need for you to have some programming skills…
Thank you ! Thats very helpful
Many devices have an entry on their menu to show the relay state. But it’s readonly.
Easiest, if you have that option is to just enable it by modifying the qml file responsible.
Here is how it looks on my Multi RS. (It’s enabled on my system)
1
