How can I modify "Limit system feed-in" state on NodeRED?
Is it possible to modify this parameter via NodeRED?
i have a fronius primo on the AC in input at my multiplus2. Controlled via modbus by cerbo, and it works fine, but I need to activate or deactivate “Limit system feed-in” via NodeRED depending by the MultiplusII Switch position, any help, please, thanks
Hi domoticadcm. Yes, it is possible. See the attached JSON example. Inject different power values to verify the changes in the Cerbo GX Grid feed-in interface. Ensure you update the IP address of your Cerbo GX device in the MQTT broker node.
Max feed-in TEST.txt (4.2 KB)
