Hi, I am using threephase multiplus 2 with Fronius inverter.
When I put on the slider in Cerbo GX menu [ Limit system Feed-in] manually the system throttles to zero feed-in and works like a charm.
Now I want to automate this with Nodered so when prices are negativ, it should not feed-in.
I can read /Settings/CGwacx/MaxFeedInpower in Node red and get the data.
But when I try to write the same data back, nothings happens. The slider does not change. Look that the register is not writetable. Can someone look in to it please.
