Hello everyone
I have a Victron Cerbo, Victron MPPTs and Victron Quattro. I don’t use ESS as recommended by Victron.
I have AC-in 1 (grid) connected to the Quattro but I rarely use it. I’m practically off grid. AC-in is connected only for emergency charging of the batteries. For this purpose, I was using Node Red successfully, except Node Red randomly freezes. I don’t want to risk this happening just when my batteries need charging from the grid. So I’m looking to cut out Node Red completely by using quattro/multi assistants to control AC-in. I could use the cerbo or external smart switches, but I don’t want to go that route unless I must. Quattro/multi VS is not an option.
There are many related questions on the forums but I couldn’t find the answers I need. I have followed the instructions here but nothing seems to work for me:
- The major issue is that when AC-in kicks in, it supplies the loads first and only the
left-over energy charges the batteries (see screenshot).
What I need is AC-in to charge the batteries and the Quattro to continue inverting DC to supply the loads. Can I change the default behavior much as it appears to be normal?
2. It seems the link I’m using is old, as my PV Assistant Support is very different. (compare my screenshot with Victron’s).
Note that I don’t have any PV inverters or panels connected to the Quattro. Do I still need the PV Inverter Assistant although I have no other use for it? It seems the Generator Start and Stop Assistant in conjunction with the General Flag Assistant is enough?
4. My final question is just a curiosity: Does Victron recommend the depreciated Self-consumption Hub Assistant over the Generator Start and Stop Assistant?
Fideri
