Hello
Im using an Orion 50a with a fogstar 280ah lithium
I’ve been having a bit of a confusing time getting it setup so that i’m getting close to the actual 50a
I have a decent Standard alternator putting out over 14v
Have good cables etc
If I use power supply mode can get 50a all good
If i turn off engine shutdown detection I get 46a all good
If i use engine shutdown detection I can never find a setting the works. I’ve tried using the default but gives me about 5a.
I tried lowering the shutdown to 12.8 but all that happens is the input matches whatever voltage i put in the shutdown voltage and doesn’t go above it, which makes no sense. if i increase the shutdown to say 13.4 then the input jumps to that but lowers the amps.
Shouldn’t shutdown just monitor it and if falls below that turns off, not makes that the default input value ??
I’m really confused
