I’ve got an Orion 12/12-30 in my Four Wheel Camper in the back of my 2012 Tundra to charge the leisure battery. (100AH FLA, but soon to be 280 AH LIFEP04) I’ve got 4ga cable running from the starting battery to the camper, then into the camper wiring which I would estimate at 10 ft of 10ga to the Orion.
I have engine shutdown detection enabled,
start voltage @ 14,
delayed start voltage @ 13.8,
delayed start voltage delay @ 120s,
shutdown voltage @ 13.2
in battery settings I have
absorption voltage @ 14.5
float voltage @ 13.20
bulk time limit @ 10 hr
re-Bulk offset .40v
adaptive absorption time switched ON
Max absorption time @ 6hr
input voltage lockout 12.4v
restart value 12.6v
I bought this Orion used and these were the settings in it so haven’t made any changes.
I am having an issue where The voltage ramps up to 13.9-14.1 under engine RPM. (around 2000 to 2500 RPM) The Orion starts charging but very shortly, like 10 seconds the input voltage falls down under 12 volts and it shuts the charger off. A few minutes later it does it again. At that RPM, the alternator can put out 270 amps so I can’t imagine that is the issue. Any help would be greatly appreciated.
