Hello, just bought a rig with Victron system
I shut the system down using the system disconnect switch. When I turn it back on and the system was 100% charged, only the AC outlets are working. The bed lift, refrigerator is not coming on? All the lights on the various Victron components are on, inverter is on. There has to be a simple solution, it was all working before. I have no manuals yet, so looking for help!
I think its good money spent to have a professional inspect and walk you through the system. Even simpler Victron systems require some education.
I’m planning on having it rewired, its a rat’s nest of wiring. Just trying to get it up and running right now. It has to be something simple.
You’re a bit light on detail. What’s a “rig?” An RV/caravan? What disconnect switch - battery disconnect? Are you plugged in to shore power? Bed lift, refrigerator run off battery/DC?
If not plugged in and you’re getting AC from the inverter, the battery must be good, so I’d start checking fuses on the DC side.
