Globallink 520 and VRM
I have a globallink 520 on my boat. There is a solar regulator and a BMV700 both connected with VE cables. From home I can see most of the data using the VRM website. For the BMV700, I can only see voltage, current and SOC. Is it possible to view other data such as last discharge depth and time since last full charge etc the same way as this can be viewed locally. Please excuse me if this a dumb question, I am quite new to this.
Yes, you can view these in VRM. To do so, go to the “Advanced” tab of your VRM installation, then click the widgets settings icon at the top right corner of the page, and find and enable the Battery History widget for your BMV. That widget contains those specific values you mentioned.
Excellent, many thanks:-)
Angus
