The Global Link transmits all data reliably to the portal. However, when shore power is lost, the BSC stops sending data. That is to be expected. But even after reconnecting shore power, no data from the BSC reaches the portal. If you access the Global Link locally, you can see that the BSC is connected. Data transmission resumes after re-pairing the BSC within the Global Link—until shore power is interrupted again.
What can be done to ensure the BSC reliably sends data to the VRM portal even after a shore power interruption?
I have connected every device via Bluetooth. Every Firmware ist Up to Date. What die you mean with the hint to the settings? Wich settings could trigger this behaviour?
Do you have any problems connecting to the BSC with VictronConnect after connecting to shore power?
And do you also first connect with VictronConnect to the BSC before you connect to the GlobalLink or can you immediately connect to the GlobalLink and enable the BSC reception again?
No i dont have any trouble connecting the BSC via Victron connect.
Normally, I don’t connect via VictronConnect because the system operates autonomously—which is the whole point of the Global Link. The Global Link is connected to the battery, so it runs continuously, whereas the BCS only operates when shore power is available. However, I don’t quite understand what you mean by re-activating the connection to the BCS within the Global Link.
Since the system operates autonomously, I normally cannot re-establish the connection to the Global Link via VictronConnect—after all, I am not on site.
To clarify, you mean that (a) the BSC is listed as entry in the “Smart devices” menu, and (b) the entry has the toggle set to enabled, and (c) the entry shows a non-zero signal strength?
Could you clarify what exact steps and you take (in which order) to perform this “re-pairing” you mention?
