Get EV Consumption data from VRM API via Node Red
Folks, trying to find is it possbile to get EV consumption data using vrm API in node red.
Only these is the drop-down list. But in UI you definitely have this data available.
Please suggest any other place I can get it if it’s available
Hi, thanks, it will be added but not sure when.
Can you use MQTT instead?
Hah, mqtt, that right! Thanks!
