I am running Version 3.51 and have an issue within Generator Start/Stop in that periodic run does not seem to work anymore. I currently at sea in my vessel and it has been working previously but stopped a couple of days ago, Manual Start works fine, so there does not seem to be a physical issue, but I use periodic run every night to charge batteries and shut the he set off when batteries are full.
I cannot reproduce this issue on Venus OS 3.51. I tested the periodic run with and without the “Run until battery full” setting enabled.
Can you check the following:
Is there a battery service present and is it selected as battery monitor? (Settings → system setup → Battery monitor)? If this is not there and the “Run until battery charged condition is set”, then the periodic run condition will not start the generator.
Are the start time and date set correctly?
Let me know if you keep having problems. I can also take a look at your system.
Regards,
Rein.
Thank you for following this up, I can confirm that there is a battery service selected (via the VenusGX CAN Bus) and there is an alternative of the Quattro device.
I have attempted to use both battery monitors and it does not resolve the issue and the Period Run does not initiate.
The start date is selected as daily, and I have varied the start time to suit testing. This should all be correct. I have used this for many years successfully and as stated was working fine on the new UI so I don’t quite understand why it is now different.
As previously advised, manual start with a timer selected works perfectly.
