Forecasted battery to grid incorrect
Hello! I am testing with Dynamic ESS and I’ve noticed the following: In my settings, I have limited my “Maximum export power” to 40A (9.2kW); which is the combined power of the circuit breaker for my PV inverter (20A) and the MultiPlus (20A).
I have limited the “Maximum discharge power” and “Maximum charge power” of the battery to 4000W (4kW).
However, I then see in the forecast graph that the “Forecasted battery to grid” values are determined based on the “Maximum export power” and not on the “Maximum discharge power”.
What am I doing wrong?
Thanks in advance!
It was my own mistake… I entered the “Maximum discharge power” and “Maximum charge power” values as Wh instead of kWh :upside_down_face:
