Searching for newer firmware for the Phoenix Multiplus.. ( version now is 1922115 ) so that i can connect MK3, if i do now, get message in Victron connect.. upgrade to 20.xxx version..or sometimes inverter switches off, have to connect cerbo to avoid this.
Problem is that all the pages where to get the firmware result in page 404..
You device is too old, you can’t use VictronConnect for the update.
You need to use VEflash and the firmware can be downloaded at Victron Professional.
