Fire detection sensor connected to Cerbo for remoting
I’ve a Victron setup with 2x 16KW LifePO4 batteries. For safety reasons I want to place a fire detection sensor which generates an alarm, sound, but also somehow connected to the Cerbo so that the alarm can be received remotely as well. Does such a sensor exists? What are you using for fire detections?
One with a relay then you can set up a digital input wth some node red. You will have to google it as what is available to me will not likely be available to you.
We usually place an emergency stop that is manually activated when the alarm goes off as well.
Hi i don’t connect via my Cerbo GX but each sensor is on my WiFi network, here are the ones I use above all my Victron Equipment and in the house and outbuildings.
Seem to work ok, can be viewed via their app.
X-Sense Wi-Fi Smoke Alarm for Home with Replaceable Battery, Smart Smoke Alarm Compatible with X-Sense Home Security App, Compliant with EN 14604 Standard, XS01-WX, 3-Pack
