You’ve made something that’s very simple really complex. I expect that, or rather I hope that, at some level Victron realizes that the RV market is a significant segment of their business, and that the varying power levels from different parks/pedestals are a very real danger. I would guess that it’s the same at the marine level when plugged into shore power or even running off the genset.
So I like to think that they understand the importance of serving their customers and when they have a valid suggestion that just makes sense, they would tend to run with it.
Something as simple as adding the line voltage to the Grid box is, programmatically, for them very simple. The risk of adding bugs is non-existent. It’s just pulling a variable and displaying it on the screen. That grid box is 90% empty anyway. It’s not going to take any appreciable time to add it.
It’s already displayed in the Grid section of the Victron Portal. Why? because it makes sense to see the line voltage.
Why do cars have voltmeters? Why do they display engine temperature? Why do they have oil pressure gages? They usually display both on what? Their dashboard where it’s easy to see at a glance.
It’s just beyond me that someone would find seeing the line voltage displayed offensive for any reason and argue against it especially when there’s so much value to it.
Just as one example, the voltage regulator in my genset packed it in. I had to plug my Kill-O-Watt in to see why. It was putting out 150v (!!). If that were displayed on the Victron dashboard it would have saved me a lot of time. I could go on and on about the value of it, but I would leave it like this, it’s obvious, it’s easy and it’s displayed on the Portal. Make it happen on the Cerbo GUI and I would think everyone would love you for the ability to see if the voltage is high or low at any time and you may even save your customers a lot of money and a lot of wasted time.
Here’s another one. I have a brand new computer controlled washer/dryer combo in my RV. It’s incredible. I love it. About a year in it started adding water during the dry cycle. Research showed that a small percentage of people experienced that issue and repairmen were replacing control boards to address it.
So I did the same, to the tune of $500 or so. Not fixed. Because it was intermittent I could never case it. Do you know what I found out when I plugged in my Kill-O-Watt? Every once in a while the park power would drop below 115v and the second it did that, the washer would act up. I never knew. It never occurred to me that the electronics were sensitive to low line voltage.
Why was it intermittent? Because RV park power often fluctuates and its often intermittent. Had I had the ability to glance at the screen and see the line voltage I would have seen the commonality in these instances, low line voltage. But I come back to the same thing, I don’t think you guys have RV experience or experience with RV park power. If you did, you would know why seeing the line voltage on the dashboard is very handy. Real fast way to see the genset power output too.
I find it odd that I have to make a federal case out of something as simple and easy as displaying the incoming line voltage to a company that’s entire business is based on power products and managing/monitoring power.
If your goal was to stop a very simple and easy improvement, I fear you succeeded.
