It would be nice to set a “time” settings to the alarm setting function in VRM.
For example after the last setting, “time min 60 seconds”
To have an EXTRA option, to ONLY check the programmed alarm conditions at a exact certain time.
For example is the PV input voltage from the MPPT at a certain voltage level at 8:00 in the morning?
With an an alarm as this, it can give an alarm when a mppt is stopped charging.
It can also give an alarm as example at 20:00 hour, if batterry voltage is too low before the night, and that crew is warned, to run a generator before the night.
In my view this would be a great extra function.
For others that like this also, put an “love it” to this comment, that Victron can see or that is an useful option.
