EV station NS doesn’t connect to WiFi in station mode
I pressed the factury default button inside the unit. LED is flickering blue. Release the button.
Via Victron connect, connect to EV station.
Setup and select station mode
Select my network
Confirm
But is not connecting to it
What could be the issue
Regards
Frans
Charging station was forced on a other network. Unblocked this and after reset and reconnect to correct network it was all OK.
Issue solved
Frans
