I’m having an issue with my ESS system switching from battery power to grid far too early, and I’m hoping someone with deep Victron/ESS experience can help.
Problem description:
My Victron 15kVA inverter switches to mains power and raises a “Low Battery” alarm when my Seplos batteries reach around 35% SOC.
This behaviour occurs when the Seplos BMS is in control of the system.
I then tried switching control so that the Victron SmartShunt is used instead:
At that point, the system switched to grid when the Seplos BMS reported ~41% SOC
However, the Victron SmartShunt showed ~31% SOC at the same time.
So there seems to be a significant SOC mismatch, and regardless of which device is in control, the inverter is switching to grid much earlier than expected.
Thanks Fredd — I think you’re right to focus on Dynamic Cut-off
From what I’m now seeing, these values appear to be far too conservative for a large 48V LiFePO₄ bank and would explain why ESS switches to grid at ~35–40% SOC.
I’m planning to reduce the Dynamic Cut-off voltages in line with typical LiFePO₄ ESS values and test again.
Thank you so much and I will let you know if it fixes the problem,
just a quick note to say thank you.
I’ve been living with this problem for over three years, and after adjusting the Dynamic Cut-off values as you suggested, it is now completely fixed.
I’m incredibly grateful for your help — it’s made a huge difference to my system. Thanks again for taking the time to point me in the right direction.
I wonder if you might have an idea whyI have this other problem? My grid connection is single-phase, rated at 63A. While charging the battery overnight, I normally see grid import capped at around 10.5 kW, which corresponds to roughly 45–46A. On a few occasions—when the battery charger and my EV charger were running simultaneously—I’ve briefly seen imports of 14–15 kW, so I know the supply itself can deliver more.
This makes me think there may be:
An AC input current limit set in the Quattro
A GX system-wide limit overriding the inverter setting
Or a dynamic limit via ESS / DVCC that I’ve overlooked
Do you know?
Where the authoritative AC input current limit should be set (VE.Configure vs GX)?
Whether ESS or DVCC can silently cap grid import under normal conditions?
And which value would be appropriate for a 63A single-phase supply?
I’m going to try this. My energy consumption is huge running an EV and 2 heatpumps, My annual consumption is around 26,000Kw and our prices have gone through the roof.
So to confirm my understanding:
the ~10.4 kW limit I’m seeing is the maximum output of the Quattro’s internal charger (200A @ ~52V), not a grid or ESS limitation.
That explains why I can briefly see 14–15 kW import when charging the EV at the same time — the additional power is going directly to loads, not into the battery.
I appreciate the clarification — that clears up my confusion completely.
