ESS phase balancing issue: buying and selling electricity at the same time
Today I discovered that when DESS schedules exporting excess solar energy to the grid instead of charging the batteries, it does so unevenly across the three phases. As a result, I end up buying electricity on one phase while exporting it on the other two.
In the screenshot below, the system is exporting a total of 1996 W to the grid, but the phase distribution is:
  • L1: -468 W (export)
  • L2: -2516 W (export)
  • L3: +988 W (import)
This means that while the system is exporting nearly 2 kW overall, L3 is simultaneously importing almost 1 kW from the grid.
The issue is that my utility treats each phase separately. Energy imported on one phase is not offset by energy exported on another phase. In addition, the purchase price is roughly €0.10/kWh higher than the compensation received for exported energy. Therefore, even though the net power flow is approximately 2 kW exported, I am actually losing money.
Is there a setting that would prevent this behavior?
The MPPTs connected to the L3 inverter are producing approximately 2.8 kW, while the load on L3 is about 3.7 kW. The missing power is therefore being imported from the grid, whereas I would expect it to be supplied from the DC bus (battery/PV system).
In my opinion, the power flow should be balanced so that L1 and L3 are close to 0 W, with the excess power exported mainly on L2, resulting in approximately -2000 W on that phase.
Is this the expected behavior of DESS, or have I misconfigured something?
I know that there is an ESS setting for phase regulation “Total of all phases” or “Individual phase”, and I want the latter one, but this setting is not available for Multi RS Solar.
Does ess phase regulation set to individual phase not help?
But where is this setting in Multi RS Solar?
Ah, apologies.i missed that.
I think it is on the to do list. Read that somewhere, there is work still being done to get the RS to the full VE Bus functions.
A further question thought do you have a grid input current limit on the system?
This is important to me. I hope somebody can comment on when phase regulation setting will be introduced for Multi RS.
For example, the current sell price is almost zero (0.002 EUR to be exact). In this screenshot, I am giving away more than 800 W for free while buying 1590 W at a price of 0.09 EUR. I would rather prefer those 800 W to go towards self-consumption.
Oh my. This does disqualify the Multi RS for me. My grid operator also (fairly!) makes us pay if we use the grid to transfer energy between phases. This feature is so basic I never imagined it could possibly be unavailable.
I have the impression that when your loads are on ac-out it doesn’t do multi-phase regulation. My house is on AC-out.
I have a SMA on L3 on the AC-in, and the multi rs wasnt able to sink the power into the battery so on that phase i got -900W and the others were on 0. The installation is failry new so i’m still learning.
