ESS parallel to 3-phase delta grid (no neutral) with Dyness PowerBrick Plus — feasibility check
Thanks for the clarification. Regarding the single MultiPlus on L1-L2 with Node-RED correction — has anyone actually implemented this in ESS mode with a Dyness battery and confirmed it works stably? What specifically is wrong in VRM — just the display or also the actual charge/discharge control?
