Hi everyone,
I have an issue on two installations configured with ESS in dynamic mode, both using the EDF Tempo tariff system in France.
The normal off-peak and peak hours are:
- Off-peak: 22:00 - 06:00
- Peak: 06:00 - 22:00
Both systems use:
- Device: Cerbo GX MK2
- Firmware version: v3.54
The first installation, « Famille Blettner », is working correctly — the switching times between peak and off-peak hours follow the EDF Tempo schedule even after the recent daylight saving time change.
However, the second installation, « Les Mugues », has a time shift issue:
- Before the DST change: the switching was already off by 1 hour
- After the DST change: it’s now off by 2 hours
Both systems are configured identically, so I’m struggling to understand why one behaves correctly and the other doesn’t.
Has anyone experienced this issue with ESS dynamic mode and EDF Tempo tariffs? Any ideas on what might be causing this time shift or how I can fix it?
Thanks a lot for your help!
