I see some companies are now releasing a digital switching solution for victron cerbo.
Ive made a system based on esp32 and wondering if its all possible to interface with the cerbo.
Would anyone know if this is possible?
Thanks
Shelly relays are ESP32 based - they use MQTT. You have that and quite a few other possibilities via NodeRED
Certainly! Node-Red & the GX MQTT broker are the anwser. If you want to use the ESP32 only as wifi-to-remote IO I highly recommend to use the tasmota firmware for ESP’s. How to do it exactly? well google is your friend.
