My Ekrano used to be able to connect through my mobile phone hotspot. Now it doesn’t even recognize the phone hotspot and I’m unable to make an internet connection for remote access.
Ekrano no longer detects my mobile phone hotspot
What troubleshooting steps have you tried?
Reboot?
Rollback?
Does it broadcast its own hotspot still?
Did you make any other changes recently?
Newbie here. When it was first installed in June I did see the Wi-Fi connecting through my phone. Then it stopped working.
Have not tried rebooting.
Have no clue what rollback is.
Lots of trouble with the Victron system. Nearly impossible to get help from my installer. Besides which he is not an expert IMO.
Len Bertaux
Ok. Well under the VRM portal in the settings menu there is a simple feature (if it was previously connected). Its called reboot on no contact. You can set the interval there where it tries to auto recover the connection. (It includes a self re boot)
Thanks I will look into that and see if I can reconnect.
So it’s works sporadically. 2 days ago I could connect. Today nothing. Can’t work with troubleshooting pros if they can’t use VRM. I’ve rebooted with no luck.
Any way to manually connect to the hotspot? This is pretty sucky.
@Walkabout did you resolve your issue?
If yes, how? I have a similar issue. Two ekrano on side by side for two systems on a bus and one of the unit connected once but no longer seem to be able to even discover any wifi…
There is a steep learning curve for sure in the beginning. Sorry I missed your reply.
The manual has more information.
It sounds like signal strength or stability is the issue.
