Easysolar II GX 48v 3Kw Generator advice
The guide for the easysolar 3kw suggests a 5kva generator - will this unit work on less powerful generators? Also, any suggestions on brands? I x pylontech 5kw
I saw this one if 5kva is required
I would always follow what the guide suggests but always a good idea to ask.
Regarding the generator, a diesel generator would be the best option. However, the most suitable choice really depends on your intended use. If it’s just for occasional use, the suggested one should be adequate. On the other hand, if you anticipate using it for extended periods, I recommend considering the alternative below.
Ultimately, it’s your decision as you have the best understanding of your specific needs.
@nesswill thanks for the advice :+1:
