MPPT 100/50 Max Wattage
Ok, probably a dumb question, but here goes. The operation manual for the MPPT 100/50 states a nominal PV power of 700watts (12v). The specifications note- 1a) The solar charger will limit input power if more PV power is connected.
What is a safe limit, what are the risks.
Are 2x 440w likely to cause problems.
Thanks
Geoff
Hi. The only real limits are panel Voc and Isc. It depends how you wire the panels (parallel or series) to determine that. Exceeding them can cause mppt failure.
The panels you quote should fit within spec, but to be sure, run them through this… https://mppt.victronenergy.com/
