Dynamic Power Limit of Virtual PV Device Node is always 1000
When I use the Virtual PV Device Node I see dynamic power limit in the gui of the cerbo but the limit always stays 1000, even when I write a different value to /Ac/MaxPower using a custom control node.
Update: When I inject a json string with {“/Ac/MaxPower”:3000,“StatusCode”:7} at start to the virtual device node which has initial values enabled it works correctly. Only the custom control nodes don’t work.
V3.75
