I use the Nodered virtual pv node for getting my pv production into the Victron. At the moment I do dynamic power limitation via node red using own logic. It would be better if there is a virtual pv device node that outputs the pv percentage required like with modbus pv inverters, so dess is aware and capable of pv power limitation.
Can this be implemented?
