Downgrade of evcs fw?
I just got the EVCS installed and at first it somewhat worked when forced into manual mode. Then I upgraded to fw 2.02 without much further testing and since then I can’t charge the car at all. To check if this is really different with the older fw or the issue is somewhere else I would like to downgrade the evcs. But I found only versions 2.xx. Is there any way to downgrade for me to try again, or is the fw upgrade a one way ticket?
Car is a Mitsubishi I-MiEV from 2011 which also means I’m using a Type 2 to Type 1 Cable which might be part of the issue
Victron Professional (free account needed):
argh damn, I overlooked the ‘old versions’ folder… sorry, it was a long day for me X)
