Does the VE.Bus Smart Dongle work with twenty-four volts
I looked at the manual for the VE.Bus Smart Dongle and there is no mention of voltage requirements for the device. I don’t want to damage it if it can only handle twelve volts.
Thanks for you help.
Dean
It’s designed to work with all units, so it should cover the entire voltage range. It should be the same as a Cerbo for example 8-70V. The specifications should be in the manual somewhere if you can’t find you can contact the Victron dealer.
106441-VE_Bus_Smart_Dongle-pdf-en.pdf (3.4 MB)
Thanks for the information.
Thanks.
