DIY Project: Linking my old 24V Hydro system to a new 48V Victron setup. Diagram check
Well as I understand, from Mike’s explanation, in my other post. Maybe the strike is not directly to the panels so I will not have all the power of the lighting coming through, just a side charge, if my protector is 600v and my system only can receive 250v, it will get toasted before the surge protector even gets activated.
That is why a system should and MUST be grounded outside the building and connected directly to the ground. This is called external lightning protection. The stage inside the house is only the last barrier. Believe me… even this voltage is far, far above 600V… we are talking about a lightning strike of several 100,000V and several 100 kA… A small surge protector makes no difference…
OUTSIDE… VERY IMPORTANT…
Inside… You can do it… 600V is okay.
The panels will be on the ground not on the roof, and the surge protector will have his own copper spike to ground. All of this will be 15m from the house, but at a higher altitud than the house.
Maybe that is why for the sake of me, I can’t finde anything lower than 600v surge protectors?
I’m sure there are some for 250V too… but many of the major manufacturers are already at 600V + string voltage.
So don’t worry too much about 250V or 600V… If lightning strikes… then there will be a LOT of voltage. The surge protection MUST be installed as close as possible to the modules. WITH GROUNDING
The cable routing from the modules to the MPPT is also quite interesting. Here, too, a voltage event can occur when laying the cable IN THE GROUND…
So you think that a 600v surge protector with a 10mm2 cable to a coper spike just near the panels and after the fuses of the strings, will do the trick?
Ground the frames of the panels and then into the ground… preferably with stainless steel V4A or aluminum… otherwise it will corrode… from the surge protector also into the ground… 10mm is not much, but better than nothing… Lightning is definitely not picky :wink:
Nice drawing. Can you tell me what program you used and where you found all the Victron images to import and use?
Hello @Charris1950 I used the old trusty Inkscape.
Inkscape - Draw Freely. | Inkscape https://share.google/bG57eEChJQuMe3LV4
not sure if it is relevant but you might also add a Victron meter ET112 ( a Carlo Gavazzi ) to monitor the system output.
Hello! Sorry for the late reply, that suggestion is just to know how much energy I’m using? But every electron I’ll use comes out of the Multiplus, I have an isolated installation. So I don’t know why I should use the Victron meter. Can you expand in your idea?
By the way! I have already received all of the components I need for the installation, I’ll be posting photos and questions really soon :slight_smile:
It’s not really necessary, just handy for monitoring and data logging of AC power/loads when integrated with a Cerbo GX. The ET112 is more often used in grid-tied systems (ESS). Thank you for a great post with diagrams.
