Problem Statement: I am changing the Inverter Mode to “Inverter Only” from On”, using VRM, when the PV Charger is about double the AC load. Battery SOC should not be lower than 85%. Could this be done automatically with NodeRed?
Reason: Why draw power from the grid when you do not need to, even if it is very little, so as to stop export / feedback?
My solar solution:
Quattro 48/8000 grid tied
Asistant: ESS (no export / feedback to the grid)
Battery: 10kWh Freedom Won Lite
Cerbo GX
Panels 2.76kW
MPPT: RS450/100
Minimum SOC: 80%
Grid Setpoint: 30W
There is most probably additional logic which will need to be applied.
Has anyone done something like this?
