Disabling inverter when SOC <20%
System consists of 800W solar input, 150/35 MPPT, 500A Shunt, 200AH battery, and 12/1000 Inverter w/Cerbo GX.
i’d like to shut down the inverter when SOC < 20%.
can this be done?
P.S. Currently shutting off inverter when battery voltage < 11.1V
If you have a lipo battery, less than 11.1 voltage is under 10% SOC. If you want your system to shut down earlier, increase the shut down voltage under VE Configure inverter tab to about 11.6v. You may have to experiment to settle down to a specific figure. Or you can set the inverter to shut down based on SOC.
