DESS Multi RS charging and discharging in same hour
Hello im seeing that my multi RS is charging the batteries from pv and discharging the batteries to the grid in the same hour. DESS predicts that all PV will feed back in the grid and no battery charging.
Setup :
  • 3phase grid (3x25 A)
  • Cerbo GX
  • 1x Multi RS Solar on L2 with AC limit set to 25 A
  • 19,2 kwh Dyness connected with can to Cerbo.
  • 8x 425Wp and 7x 425Wp PV strings.
  • (D)ESS enabl ed
  • VM-3P75CT FW V1.11 grid meter connected to lan
  • Venus OS 3.8 0~33
  • MultiRS FW v1.30
Situ ation
  • Expected behavior: DESS predicts and indicates it will feed all PV back in to the grid.
  • Actual behavior: Battery charge from PV and discharge to grid in same hour.
Today is it working as expected without any changes.
