This is an elegant solution to increase the SoC precision. Mine is already 0.1, but calculating it myself would in my case at least increase it 3 fold (330ah battery).
Is there an easy way to copy all DBUS values into the virtual battery? or do i really have to connect 20+ input nodes into it.
And I assume you have to select the newly created battery then as the battery monitor in the gx gui.
