DC Loads includes AC Charger
Hi all, I have a SmartShunt monitoring the charge coming from a Centaur. That shows up really nicely in the new UI (as AC charger) but that charge isn’t deducted from the DC load, in the same way Alternator (Orion XS) and Solar (MPPT) are. Is there anything I can configure to fix this?
Do you actually have DC loads? Are your DC loads calculated or measured? Ideally the dc loads is actually measured by a different shunt dedicated to that purpose.
Yes I do have DC loads. Technically the Centaur SmartShunt is another DC load, but so is the MPPT and Orions. But the software doesn’t count those as part of the DC load number.
if I have the maths correct DC load should be 38w.
FYI, changing the type to Fuel Cell fixes the maths!
I definitely think this is a bug.
