Dashboard anzeigen auf Ekrano GX
So könntest du es mit einem (virtuellen) Schalter am GX umsetzen:
(geht vielleicht noch eleganter, aber das fällt mir dazu gerade auf die schnelle ein)
        "id": "5edc9935dee674e9",
        "type": "victron-virtual-switch",
        "z": "6275bec289f837bf",
        "name": "",
        "outputs": 2,
        "switch_1_type": "1",
        "switch_1_initial": 0,
        "switch_1_label": "[\"EIN\",\"AUS\"]",
        "switch_1_customname": "Test ",
        "switch_1_group": "Test",
        "switch_1_include_measurement": false,
        "switch_1_rgb_color_wheel": false,
        "switch_1_cct_wheel": false,
        "switch_1_rgb_white_dimmer": false,
        "x": 280,
        "y": 400,
        "wires": [
                "ea7f98fab31a860a",
                "3822e3feaccdddab"
        "id": "ea7f98fab31a860a",
        "type": "debug",
        "name": "debug 5",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 500,
        "y": 600,
        "wires": []
        "id": "79dda3db0498db95",
        "type": "trigger",
        "name": "",
        "op1": "1",
        "op2": "0",
        "op1type": "num",
        "op2type": "num",
        "duration": "1",
        "extend": false,
        "overrideDelay": false,
        "units": "s",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 740,
        "y": 360,
        "wires": [
                "f8ddc7cbfe456785"
        "id": "78d12c4226de43e5",
        "type": "trigger",
        "name": "",
        "op1": "1",
        "op2": "0",
        "op1type": "num",
        "op2type": "num",
        "duration": "1",
        "extend": false,
        "units": "s",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 740,
        "y": 440,
        "wires": [
                "712af5db2e5f17d8"
        "id": "3822e3feaccdddab",
        "type": "switch",
        "name": "",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "1",
                "vt": "num"
                "t": "eq",
                "v": "0",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 530,
        "y": 400,
        "wires": [
                "79dda3db0498db95"
                "78d12c4226de43e5"
        "id": "f8ddc7cbfe456785",
        "type": "debug",
        "name": "debug 6",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 960,
        "y": 360,
        "wires": []
        "id": "712af5db2e5f17d8",
        "type": "debug",
        "name": "debug 7",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 960,
        "y": 440,
        "wires": []
        "id": "f7f8f7d3998bb1ed",
        "type": "global-config",
        "env": [],
        "modules": {
            "@victronenergy/node-red-contrib-victron": "1.6.63"
Statt dem Debug 6 und 7 kommen die Relais vom Cerbo.
