Today I use non-inverting cables from BMS to shut down several mppt’s (Smartsolar 75/15) if there is something wrong when charging my batteries (2x200Ah NG). But these cables are occupying the VE.Direct ports on the MPPT’s and now I’m thinking of adding a Cerbo Gx to my system and want to connect the MPPT’s. Can I use a Cyrix-Li-Charge (controlled by BMS) to protect the batteries or will I destroy the MPPT’s to cut the charge output without using the remote control?
