## Controlling Relay 0 and Relay 1 (Open Collector) from Node-RED on EasySolar II
Hello All,
I have sum up below the information for this post:
Goal:
I want to control the two programmable relays (Relay 0 and the Open Collector K1) directly from Node-RED flows, without using VEConfig assistants.
Setup:
  • EasySolar II 48/3000/35-32
  • Venus OS 3.73 (integrated, no external Cerbo GX)
  • Pylontech battery
  • SmartSolar MPPT 250/70
  • Node-RED via VRM Portal
What I have already done:
  • Removed the “Programmable Relay” assistants from VEConfig to free up relay control
  • Verified that relays work correctly when controlled via VEConfig assistants
  • Confirmed Modbus TCP is enabled in Venus OS settings
What I have tried:
  1. dbus via Node-RED exec node:
    Scanned all services for relay paths. The path /Relay/0/State does not exist on com.victronenergy.vebus.ttyS3 or com.victronenergy.system.
    Only relay-related paths found on vebus are internal protection relays (GridRelayReport, RelayTest, etc.).
    The path /Settings/Relay/0/InitialState exists on com.victronenergy.settings and is writable, but does not control the relay in real time.
  2. Modbus TCP:
    Tested all Unit IDs listed in Venus OS (100, 225, 228, 229, 230).
    Only Unit ID 225 (Pylontech battery) responds correctly.
    All other Unit IDs, including 228 (VE.Bus/MultiPlus), return: GatewayPathUnavailable (Exception 10).
    Tested with both node-red-contrib-modbus and pymodbus directly.
  3. Custom Control node in Node-RED:
    The MultiPlus-II appears in the device list, but no relay path is available in the Measurement dropdown.
Questions:
  1. Is there a working method to control Relay 0 and the Open Collector K1 from Node-RED on an EasySolar II with integrated Venus OS?
  2. Why does Modbus TCP return GatewayPathUnavailable for the VE.Bus Unit ID 228 on this integrated setup?
  3. Is there a specific dbus path for real-time relay state control on this device?
Any help or pointer to documentation would be greatly appreciated. Thank you!
