Control DVCC via Node Red?
Hello
I´m starting with Node Red and like to do load regulation which I have done before from external control by usage of Modbus.
Therefore I like to control the DVCC settings and set Max Charge Voltage, but this seems not be to allowed by victron custom control Node.
Looking for sth. in com.victronenergy.settings /Settings/Dvcc/MaxChargeVoltage
Additional Nodes like D-Bus Nodes seems to be also no longer available/installable.
Kindly ask for recommendation and would prefer sth. without mqtt usage.
Thanks
You need Settings/SystemSetup/MaxChargeVoltageV
I have this working well plus MaxChargeCurrent.
what do you mean with load regulation? Why you want to change Max Charge Voltage for that?
isn1t it the current you want to change?
Thank you very much. Haven´t seen it before and systemsetup was the key to find it :slight_smile: !
