Configuring MPII 2x120 (24v) for Split Phase (US)
Hi All. I am not new to Victron and have done many Quattro split phase systems in houses. Never had any issues and everything just always worked, for the most part.
I’m rebuilding a camper power system with two MPII 2x120 units. We need 240V split phase output to run a well pump.
My Quattros in the past have only one L AC output and I dedicate one for L1 and the other for L2.
These 2x120s seem a bit different. Are they configured the same? I have seen conflicting information on usage of L2 (some documentation says this is disabled in Split Phase).
I wired it up using one unit’s L1 For L1 and the other unit’s L1 for L2.
Is this correct? I am still not getting 240 split phase…
Do you have the european Mp or the necessary 2x120V Type?
Please give us more details about existing components and the wiring.
Photos are great.
Edit: did you see the 180° option in the Config app? Do you have a Mk 3 Interface?
