I just bought a SmartSolar MPPT 150/35 to run six solar panels. I also have a wind generator. I idid have a non-branded Chinese hybrid controller but its internal limits would not allow me to generate more power when I went from 4 to 6 panels, so I took it offline.
I had a Renogy Rover 30, and I ran it and the wind controller wiring to the same battery bank. Apparently thge Rover 30 did not like the dump load on the wind generator, and eventually it died. Renogy would not honor the warranty becasue they said I violated it even though there was no verbiage that said I could not do this.
So my question is, with this unit work alongside a wind generator charge controller?
Wind generators do not throttle power as the batteries get fullly charged because they need to have a load against them, especially in high winds. Instead, an automatic transfer switch channels excess power to a “dump load” (a large resistor that converts electricity into heat).
During high winds, the constant load acts as a brake to prevent the generator from spinning itself apart. This is necessary. I currently have the wind generator connected to a separate battery so that it is not charging my main bank, but sill has a load on it.
It would be nice to reconnect it back to my main bank, but I din’t want to do so if it voids the warranty or if it ends up frying the SmartSolar unit.
The link to the wind charge controller is here: https://windandsolar.com/digital-440-amp-charge-controller-divert-relay.
Any advice would be appreciated.
