Dear all,
I actually have my MultipLus II GX combined with Pylontech batteries, actually no solar. To otake advantage of the different electricity costs during day and night I an preparing to use it as ESS. Consuning battery electricity when grid electricity is expensive and charging from the grid when it is cheaper. (Until my PV is up and running).
I have an EcoFlow Delta Pro which I use when I am travelling with my RV. Though I am not travelling all the time I would like to benefit from its large battery capacity and connect it to my ESS system.
Even though the Ecofloy has an inverter for 230V, I suppose it is not that easy to Connect it to the AC-In of the MultiPlus II parallel to the Grid.
Though my idea to realize a good and not too expensive solution actually is to use a DC/DC converter to level up the Anderson 12V output of the EcoFlow Delta Pro to 48V, then connect a 48V PV battery charger to the battery.
What do you think? Does anybody have a similar installation? Could it work?
Thank you in advance!
