I tried to help a user, and encountered that his data partition is 100% f…ull. Can I suggest that you change the project to prevent that, and at a minimum always have log file rotation? Perhaps just use the same type of logging that we do in venus os; it takes care of rotation.
See also: https://community.victronenergy.com/questions/286286/after-cerbo-gx-update-to-v331-i-now-get-error-67-b.html?childToView=287794#comment-287794
I checked his config.ini, logging is set to ERROR.
And the current.log file, 1.134.657.536 bytes large, is full of errors, like below one.
Thanks!
File "/usr/lib/python3.8/site-packages/requests/adapters.py", line 504, in send
raise ConnectTimeout(e, request=request)
requests.exceptions.ConnectTimeout: HTTPConnectionPool(host='192.168.178.9', port=80): Max retries exceeded with url: /api/livedata/status (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xb5bbac28>, 'Connection to 192.168.178.9 timed out. (connect timeout=2.5)'))
During handling of the above exception, another exception occurred:
Traceback (most recent call last):
File "/usr/lib/python3.8/site-packages/urllib3/connection.py", line 159, in _new_conn
conn = connection.create_connection(
File "/usr/lib/python3.8/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/lib/python3.8/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
OSError: [Errno 113] No route to host
File "/usr/lib/python3.8/site-packages/urllib3/connectionpool.py", line 665, in urlopen
httplib_response = self._make_request(
File "/usr/lib/python3.8/site-packages/urllib3/connectionpool.py", line 387, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.8/http/client.py", line 1256, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.8/http/client.py", line 1302, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.8/http/client.py", line 1251, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.8/http/client.py", line 1011, in _send_output
self.send(msg)
File "/usr/lib/python3.8/http/client.py", line 951, in send
self.connect()
File "/usr/lib/python3.8/site-packages/urllib3/connection.py", line 187, in connect
conn = self._new_conn()
File "/usr/lib/python3.8/site-packages/urllib3/connection.py", line 171, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xb5bbae20>: Failed to establish a new connection: [Errno 113] No route to host
File "/usr/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/lib/python3.8/site-packages/urllib3/connectionpool.py", line 719, in urlopen
retries = retries.increment(
File "/usr/lib/python3.8/site-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.178.9', port=80): Max retries exceeded with url: /api/livedata/status (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xb5bbae20>: Failed to establish a new connection: [Errno 113] No route to host'))
File "/data/dbus-opendtu/dbus_service.py", line 441, in fetch_url
json_str = requests.get(
File "/usr/lib/python3.8/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/usr/lib/python3.8/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3.8/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.8/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.8/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.178.9', port=80): Max retries exceeded with url: /api/livedata/status (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xb5bbae20>: Failed to establish a new connection: [Errno 113] No route to host'))
raise err
sock.connect(sa)
socket.timeout: timed out
self.send(msg)
self.connect()
File "/usr/lib/python3.8/site-packages/urllib3/connection.py", line 164, in _new_conn
raise ConnectTimeoutError(
urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPConnection object at 0xb5bea2f8>, 'Connection to 192.168.178.9 timed out. (connect timeout=2.5)')
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.178.9', port=80): Max retries exceeded with url: /api/livedata/status (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xb5bea2f8>, 'Connection to 192.168.178.9 timed out. (connect timeout=2.5)'))
File "/data/dbus-opendtu/dbus-opendtu.py", line 93, in main
service = DbusService(
File "/data/dbus-opendtu/dbus_service.py", line 84, in __init__
self.numberofinverters = self.get_number_of_inverters()
File "/data/dbus-opendtu/dbus_service.py", line 289, in get_number_of_inverters
meter_data = self._get_data()
File "/data/dbus-opendtu/dbus_service.py", line 474, in _get_data
self._refresh_data()
File "/data/dbus-opendtu/dbus_service.py", line 363, in _refresh_data
meter_data = self.fetch_url(url)
File "/data/dbus-opendtu/helpers.py", line 89, in wrapped_func
result = func(*args, **kwargs)
File "/data/dbus-opendtu/dbus_service.py", line 466, in fetch_url
return self.fetch_url(url, try_number + 1)
requests.exceptions.ConnectTimeout: HTTPConnectionPool(host='192.168.178.9', port=80): M^C
