I think you need to add a feature under the gen start stop settings to choose an alternative battery monitor. I have a 48 volt system plus they also maintain a 12 volt battery with an Orion. I have a smart shunt for the 12 volt system to monitor the battery and the CAN BUS for my 48 volt system. I have a relay installed on the Orion to allow me to charge the 12 volt as needed but I have it set up as a Gen start stop feature and I chose the voltage option. This only operates if the main battery monitor in the system setup is the smart shunt for the 12 volt system. Can you add a feature under the gen settings to choose an alternative battery monitor?
Related topics
| Topic | Replies | Views | Activity | |
| Best way to monitor a 48V system and the 12V system in my van | 2 | 52 | 26 March 2026 | |
| BMV-712 Smart Shunt Starter Battery Monitor | 3 | 122 | 7 April 2025 | |
| Need Help Selecting a Battery Monitor/Shunt | 11 | 164 | 6 January 2026 | |
| SmartShunt IP65 monitoring a 24v AND a 12 v battery? | 1 | 96 | 28 March 2025 | |
| AUX voltage monitoring with BMVxx2 or SmartShunt | 6 | 125 | 3 September 2024 |
